A problem has been detected which is interfering with the normal operation of the system. An invalid event message size has been detected during the conduit message verification process. The sending application is informed of the error - it may attempt the transmission again after some corrective action.
The exact remedy is dependant on the particular situation; but the problem may be resolved by retrying the operation when the resource becomes available.
Error
A conduit event message size of %size% is invalid - conduit type %conduitType% and conduit ID %conduitId% .
| Name | Type |
| size | uInt |
| conduitType | uInt |
| conduitId | uInt |
